Weird noise...not engine noise
  • 4
Fightingeagle12
At first I though this was just normal engine noise, but it doesn't stop when i turn off the car or get louder when I accelerate. I have seperate switches for each amp and the noise only occurs when i turn on the subwoofer amp. I did some work to get ride of the engine noise i had before, which is now gone, but no i get a high pitced squeel and random random pitch changes that sound like music from a horrible sci-fi movie. I was already thinking of adding a dedicated power wire from the battery to the turn-on for the amp...not sure if that would help much though. I don't know how turning on the subwoofer causes funny noise to come out of the speakers though?
i pulled out my Hercules which was causing the noise and replaced it with my old kenwood which is rated similar, but in reality is weaker and the noise went away...i had considered a bad ground, but why would it go away with swapping the amp?
Have you used the same size ground wire as the supply wire??I would relocate to a better ground..Scrape down to bare metal, put a bolt in with,washer,then terminal/ground wire connection, then another washer, and head of bolt covers all for solid ground connection.. need locate a solid grounding point first.. like trunk, i usually look at the spare tire mount down and alot of times I utilize that with a nut, washer,connection/terminal, then another washer,and nut.to sandwhich all together, then i put spare tire mount back in place a screw it back in place..Yet.. check your ground,make sure its bare metal..May have to relocate/possibly use larger ground wire as well??//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
Fightingeagle12
Fightingeagle12
Manchester, NH
akheathen
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
