bunkrd you
As for drilling I like corded drills but cordless drills work better for screws imo so the screws dont get over torqued and split the wood. It is also time consuming but get a squared edge and draw out 3/4ths of an inch so when you drill your holes you know it is going in the center also preventing wood from splitting. As for cutting the wood Id use lowes just because they will cut all the wood i need in under 15 minutes to be +/ 1/32nd of an in for 25$ a cut after 2 and I have yet to be actually charged.
I dont use clamps but it helps to have a set of 50lb weights and 40lb to hold it upright and sit it on top....
I use random bits as I brake them but I make sure to keep them pretty small. 1 5/8ths work but I wouldnt use drywall as I dont think they are meant to hold a lot of weight considering how light drywall is. gold screws were like 4$ for 200+ they are hard to strip out too.
