What is the loudest SPL EVER recorded????????????????????????
If you mean in general, which I kind of doubt you do, I think 200 dbs is the loudest concievable noise.
I thought our hearing only went from 1-180 with 180 dbs being a rocket launch. what on earth could make 200 dbs?
194 in air. Some science people built a machine to make it and they can shake apart a soildly built brick wall in about 20 seconds.
under water is about 230 but the amount of water that would be moved would pop your head like an unwanted zit.
if you leave are atmosphere there is no air to be moved. So high sound would be right around 0db I belive.
thanks discovery channel. //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif
i believe the loudest possible tone is 196 which can be made by a blue whale. I wouldnt wanna be near that mofo if it went off
Plus one. Works in as small of a box as .7 cubic feet sealed. Also had mine in a 1.75 cubic foot box ported to 36. ****** slammed. Only thing was...
5
248
Let me know if you still have these? Ill take them!
10
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
3K
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
supraman1379
Lifted 03 HEMI
supraman1379
Ocala, Fl
snb778
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
