What ohm load could i get?
I have 12" 4 Ohm subs..
I need just above 1 ohm, i dont want under.. any ideas??
Tim
I dont quite understand you.
How many subs do you have? What kind of VC's?
If you meant you have 12 4 ohms speakers, i THINK you can wire two speakers together in series(so 6 pairs of speakers wired in series), then wire them all to the amp. I THINK that produces a 1.33 ohm load, i'm not sure though.
uh...lol said he has 12 inch 4 ohm subs... guessing 2 subs... i dont know how the hell you got 12 speakers from what he said :/ less you missed the inch marks or something
series them into pairs, that gives you 6 8 ohm loads
parallel them into quads, that gives you 3 4 ohm loads
parallel the 3 quads, that gives you 1 1.333 ohm load
series them into pairs, that gives you 6 8 ohm loadsparallel them into quads, that gives you 3 4 ohm loads
Or you can just do what i said. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yup 1.33 ohms it is. Should pound pretty hard with 12 10's and about 2kw //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Good luck with it man.
This x2, exactly. It's been my experience that 4 ohm operation sounds better to the ear. Never more than 2 ohms for me, and 4 is better. Worth the...
55
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
Silica
Silica
Cambridge Ontario Canada Earth
BooLeaN
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
