will my design work?
  • 3
grezgorzrulz
Hey guys i have a design for a sub box for a L7 10" and i want to hide it in the side panels in the trunk. I have designed a box can anyone tell me if the layout of the box will allow the sub to perform well for that ground shaking type bass, hence the reason i went for ported box, not sealed.
The vent is approx 30cm(12") long and is 12cm(5") deep.
The overall length of the box is 60cm (24") long and 10cm(4") high.
Any help with the design is appreciated i dont know if putting the port at the end of the box like it is will be the best
If that extension is all port it will work
IMO fire the port to the side so there is not that last 90* bend right before the opening
If you are trying to get more volume to the box it will not use that volume
And if you have the port only part of that extension it will lower tuning more than desired and could cause issues
What is the port area?
I think he has misunderstood your idea. I believe that he thought the entire length was a port. The way i understand it is that the extension is openly connected to make the whole box a large L shape and the port is at the end of the L shape. From what i understand, this design should work. The shape of the box shouldn't matter as long as the airspace is adequate.
thanks for your reply, thats what i was after.
it is an extension that is openly connected just as you say.
How do i know how big to make the port? do i go by the subwoofer spec sheet for port length?
It will not work properly
That L will act as a port of its own
It can severely reduce the airflow
If not all the time you may find specific frequencies that the port will change due to the extension
Just make the L portion port only
Even better would be to have the port come out the side of the box
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
665
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
997
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
841
grezgorzrulz
grezgorzrulz
australia
grezgorzrulz
