Wth dual or triple alt bracket
  • 3
DCbass
Hello fellas, im looking to purchase a dual or triple alt bracket for a 97 ford expedition, I really need it as i have 2 alts but no bracket, and if I can have 3 under there one day i sure will. I'm in nc in case any of you fabricators would be interested in taking a crack at it, otherwise the trick has the 5.4 triton motor in it.. Thanks in advance
message jimmy zukauska on facebook he makes the brackets for js alternators. you can ask js alternators but im sure theyll just forward you to him
dc power would be my go to but they only work on GM it looks like
Yeah theres more offered to gm vehicles when it comes to car audio, im gonna look up js alts since I'm not on Facebook, thanks for the help brother
its just way easier to work on GM vehicles in this way. Plenty of space by the alternator and a lot of mounting holes for brackets
good luck
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
578
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
720
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
941
DCbass
DCbass
Kinston, NC
wew lad
