Sub sensitivity
kanihoncho
CarAudio.com Newbie
What is a good sensitivity that I should I be looking for in a sub when my 4ch speakers have a sensitivity of 93 dB (at 2.83 V). Should I be looking for similar specs or is it a completely different equation? I do see different sensitivities at different voltages and do not know how to compare them . . .
Sensitivity is usually measured 1watt 1 meter. I'd go by that.
Higher the better on subs too. Less power to get louder. Every 3 DB gain is like doubling your amplifier power.
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
267
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
433
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
855
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
538
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
417
kanihoncho
CarAudio.com Newbie
kanihoncho
South Carolina
Jimi77
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
