Kenwood XXV-05V Indianapolis
Civic96Lx
Formally 92OldsTrefeo
Kenwood eXeclon XXV-05V
Out of Car Audio for a few years now. Ive had this lingering around with no where to go. Its been a long time since I was active on this site, but hoping this can go to a good home.
If you're in Indy I have a plant audio vx900d amp as well to get rid of..
Setting out feelers for any interest in my left over items. PM me with interest. Thanks
* 7.0 inch Wide Colour TFT Active Matrix Display
* Number of Pixel: 336,960 pixels
* Screen Size: W154.1mm x H87.0mm
* New Full-automatic "Z-action"Open/Close Mechanism
* Motorized Tilt Angle Adjust (8 Step)
* Motorized Back and Forth Display Position Adjust (4 Position)
* Interactive Touch Panel Control with New Smooth GUI
* Multifunction Key Operation
* Audio Easy Control Mode
* External Hard-key Operation (When Monitor Closed)
* Partial Detachable TDF Panel with DSI & Security Code
* Mini Display = 5 x 7 Dot Matrix LCD (Blue/Green/Red)
* Selectable Key Illumination (Green/Red)
* New Amplifier Control System with '04 PS Amplifiers
EQ(Bass/Treble/Q Factor/Gain Control)
Voltage/Current/Temperature/Fan Speed Display
* Advanced B.M.S.(Bass Management System) with '02 PS Amplifiers
* Wired remote out for original mounted streering wheel remote control
* 2-way Telephone/Navigation Mute
* Digital Clock (24H)
* All-in-one Hide-away Black Box ( 5.1ch DSP/ TV Tuner/Receiver) Supplied
* Diversity TV Antenna (Window Type) Supplied
* Remote Control Unit Supplied
TV Features:
* TV Tuner (PAL/ SECAM)
* 12 TV Station Presets
* Auto Memory Entry
* SNPS (Station Name Presets)
AV Features:
* Maximum Output Power : 50W x 4 + 47W x 1 (for optional Center Channel)
* 4 Gold Plated Preouts with 5V Pre-output Level (Front/ Rear/ Centre/ Subwoofer)
* 1 RCA AV Output (PAL or NTSC according to the source)
* 2 RCA AV Inputs (PAL/NTSC Automatic Selection)
* Video 2 Input Signal Automatic Detection Mode (Normal/ AUTO/ Rear View Camera)
* Rear View Camera Connection Ready (AV Input-2 only)
* RGB Input for optionel Navigation System KNA-DV3200
* Dolby Digital/ dts/ MPEG/ Linear PCM Decode
* Dolby Pro Logic II (for 2ch Source to 5.1ch surround)
* SFC/ 4 Band Parametric EQ/ Digital X'over/Digital Time Alignment
* Sound Management System (Type of Car & Speaker Size for Each Channel Selectable)
* Dolby Digital DRC (Dynamic Range Control : Wide/ Normal/ Midnight)
* SPF (Speaker Protect Filter) Operation
* Dual Zone Source & Volume Control
* Attenuator(-20dB) with Smooth Volume Return
CD Features:
* WMA (Windows Media Audio) Decoder
* MP3 Decoder with ID-3 Tag Display
* CD Text Ready
* CD-R/CD-RW Compatible
* Direct Access with Remote
* Random/Repeat/Scan Play
DVD Features:
* DVD Video & DVD Audio Compatible Player
* DVD +- R/RW Compatible (Video Format Only)
* VCD Compatible
Changer Features:
* Dual Disc Changer Control Capability (CH1/CH2 & AUX)
* DNPS (Disc Name Presets) with Compatible CD Changers
* DNPP (Disc Name Preset Play) by Remote
* CD Text Ready with Compatible CD Changers
* Random/Repeat/Scan Play (Disc/Track)
DSP Features:
* 4 Band parametric equalizer
* Band1 frequency: 60/80/100/120/160/200/250 Hz
* Band2 frequency: 315/400/500/630/800/1000 Hz
* Band3 frequency: 1.25k/1.6k/2k/2.5k/3.15k/4kHz
* Band4 frequency: 5k/6.3k/8k/10k/12.5k/16k
* Gain -9dB, -7, -5, -2, -1, 0,1,2,3,5,7,9
* Q control: 0.25/0.5/1.0/2.0
* High pass filter frequency: 60/70/80/90/100/120/150Hz Slope: 12/18/24 dB
* Low pass filter frequency: 60/70/80/90/100/120/150Hz Slope: 12/18/24 dB
* Channel level: +/-10 dB
Tuner Features:
* FM/MW/LW 24 Station Presets (18FM, 6MW & LW)
* RDS with Radio Text
* K3i Clear Reception Tuner Circuit
* AME (Automatic Memory Entry)
* Up/Down Seek Tuning
* Local Seek
* FM Stereo/Mono Selector
* DAB reception with optional unit KTC-9090DAB
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
218
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
627
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
553
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Civic96Lx
Civic96Lx
Carmel, IN
Anthony Stempak
pfft
    May 1, 2024
pfft
    May 1, 2024
