Cd skipping
Llt1980
Junior Member
34
Iowa
I have the alpine cde-175bt with JL 15s and 1000 watt amp and every time the bass hits really hard the CD skips is this a normal problem with this deck or something else going on at this point the deck has only been in my car for 3 days and I got it new and professional install
Sounds like it isnt very well secured to the dash/the HU.Though just depends on how well the HU can hold up to vibrations within the vehicle as upon trial and error so to speak.There is no way I can run a CD in any of my vehicles past the volume of 10-15 with the power I generally run.And as for a flip out unit? Ive had one last about 3 weeks tops before falling apart.USB or a Laptop or bluetoothe is where I have to listen to music other than the radio stations.Transfer your music to a USB drive or continue having issues. You may want to see about bracing the HU behind the dash to see if this helps
what is this "CD" contraption you speak of? joking aside, it shouldnt skip as badly as youre describing unless you have what audiobaun is describing. I second the notion of getting a flash drive or put your music on your phone and BT it
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
Llt1980
Junior Member
Llt1980
Iowa
youdoofus
