Need help with choosing an amplifier
  • 2
Brandon Kahi-Waugh
Hi. I currently have installed a pioneer head unit with 55wx4 output capability and subwoofer control.
Fusion 12" sub and amp combo (900 watt amp)
Rear JBL 6x9s (550rms iirc)
Front jvc 300 watt compoments with 60w tweeters.
In the rear doors in have stock speakers.
I'm wanting to replace my stock rear door speakers and hook all of my 6 speakers up to an amp as my head unit just cant do the system justice but know next to nothing about Amps. What should I be looking for.
( powered by 450 battery)
Trying to keep under 500 if possible
are you trying to run the fronts with passive crossovers?
Yes I believe so.
 On A side note Im not even sure if my rear door speakers are functioning at the moment so might just focus on the fronts and rears.
Yes I believe so.
probably not working if you have fronts and rear dash speakers and just a deck to power them all. If youre wanting all 6 sets of speakerss hooked up simultaneously and the rear doors and back dash speakers to work independently of each other, then youre going to want a DSP and at least 6 channels of amplification. and if youre going that far, might as well run active crossovers on the front mids and tweets instead of those passives. You could ghetto rig it and have the back dash and rear doors off the same rca's from the deck and have a 4 channel running them and set the gains lower on whichever pair is louder to balance them out. This might be more of an undertaking than you expected, but its nowhere near impossible for you to figure it all out as its not at all rocket science
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
Brandon Kahi-Waugh
Brandon Kahi-Waugh
youdoofus
SlugButter
    May 4, 2024
slater
    May 2, 2024
