Audio Control ?
  • 6
Post what type of enclosure you're thinking of using and how much space you're willing to give up for the enclosure. Type of music you listen to also.That'll help people point you in the right direction. Also since you'll be using a dsp I'd consider raw drivers from places like parts express or madisound. You'll want to invest in sound deadening for your doors or it'll be all for not.
Idk what your budget is like but I'd consider adding a monoblock amplifier and doing a 3 way in the front or 2 way and rear fill. That will give you more options on subs too.Probably happen anyway once you get the bug.
@shredder2 has been our box guy as of late, but he has been absent due to some stuff going on in his life. There are online box calculators and a downloadable .exe that i cant recall the name of at 758am. Someone will likely chime in and correct this for us tho
winisd for modeling
I can't find anything on this? What's modeling anyway? Since I don't  know any of the information you've told me about could you please explain it to me? What's a box guy and a box calculator also?
Sorry op but @youdoofus has shared information that could be beneficial to me... Don't mean to hijack
But seriously why r u this sh#t???
modeling is putting the thiele small parameters into a program (WinISD) and having it tell you what the output will be based on many variables. Itll show you what your freq output will be based on the sub, its db sensitivity, etc etc. If youre wanting a specific freq to be at its max, you can use this tool to see what will happen if you change the port length, box size etc to get what youre looking for.
Whatever! Don't be a p**y and answer the question
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
Patrick Lee
Patrick Lee
Shaun Beier
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
