RF Power 800a4 and Audio Control EQX
  • 2
Tim Schroeder
CarAudio.com Newbie
Hello, I have a Rockford Fosgate Power 800a4 and trying to use an Audio Control EQX Concert series processer. I have an Audio Control EQX Series 2 and an Audio Control EQX Concert series. The EQX Series 2 works fine but the EQX Concert series will not make a sound. I have hooked the EQX Concert series to 2 200a4's and a 400a4 and it works fine. Both work with the other 3 amps. The EQX Concert series will not work with the Power 800a4. Does anybody have any idea what might be going on.
I have tried it both ways. The concert series I bought new from Audio Control. Series 2 used. I had this amp and Concert series in another truck with a bd1000a1 and a 200a4. Also had a 6xs 3 way crossover concert series in that system.
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line converter in and hooked both up line level and had the same results. No sound out of the Concert Series. I've bypassed all speaker wires one at a time to make sure a wire isn't pinched or something wrong and nothing changes.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
437
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
344
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
711
Tim Schroeder
CarAudio.com Newbie
Tim Schroeder
Lewisville Texas
Tim Schroeder
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
