AWG FOR MY AMP?!?
  • 2
Use 100% oxygen free copper wiring sized to carry the current load that your amp draws.
The smallest size I would use it 8ga. If it was my own install I would used 4ga, because the current draw is at the upper limit for 8ga. If you upgrade in the future you already have the larger wire installed if you use 4ga. The cost difference between 8ga and 4a is negligible imo $30 vs $50.
thanks buddy hope u know what ur talking about :)
why do u recommend this brand?
Yea Knukonceptz makes great products, their wiring kits are a good value for high quality.
The only time I wouldn't use Knukonceptz is for a large install with a big quantity of large gauge wire, that's when welding wire by the foot and sourcing your own connectors is a better route.
It should work well enough for you to get solid connections. That’s about the same price I paid for this one, and I‘d bet all the cheaper...
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
Run 4g for power (or 1/0 if you can). There is no downside to bigger wire, and you won't have to replace it if (when) you go bigger. Speaker wire...
868
  • Locked
237
Amp
271
Rawb1984
Rawb1984
Canada
Rawb1984
    May 12, 2024
    May 11, 2024
