Ground loop
  • 1
broncoupe
Junior Member
13
uk
Connected a Mosconi amp to a Porsche PCM unit
The Mosconi is compatible with the Porsche output, many others have just soldered RCAs to the outputs and all good
Not me massive ground loop tried every earthing trick, only thing that clears noise is ground loop isolators.
I know you can say job done but is it possible noise is in the original Porsche headunit
Any help or ideas
Any help or ideas
Simply sorted all the forums I read said the output was a low level signal
Infact when I looked at the quadlock it is infact a speaker line signal
Same meat different gravy
All sorted no noise
If this is in the sticky I’m sorry but if you haven’t tried grounding the hu frame to the metal in front of it in your dash, that’s a good idea.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
broncoupe
Junior Member
broncoupe
uk
broncoupe
    May 18, 2024
    May 16, 2024
