Speaker level ground ?
  • 1
I’m installing a amp using line level inputs instead of rca inputs because of factory stereo. The Amp is a 5 channel so I can power both front and both rear speakers plus a sub in the trunk.amp comes with 3 separate speaker wire harnesses for each channel.each harness has 5 wires.two wires each for positive and negative and a third black wire I’m assuming is a ground wire.amp manual doesn’t indicate what the wire is for. Should I tie it in to the negative side of each speaker or run it to chassis ground where amp is grounded?
blumule
blumule
greensboro nc
blumule
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
