MD3000.1 Is the Real Deal
  • 6
Bobbytwonames
Trigger Man!
13,030
1,815
Vegas
I had my Taramps MD3000.1 hooked up today. It is running a American Bass HD15D2. I promise you that the gain is only 1/4 to 1/3 turned up and the bass is ridiculous. I only have a 95 amp alternator and two H6 AGM batteries and big three. My voltage stays consistently netween 13.0 and 13.7 while driving. This amp is very impressive. Rated at 3,000 watts @ 1 ohm at 12.8 volts. Still tuning it in because I blew a pair of tweeters up.
How is the Bug holding up?
Is all that peel and seal in there making a difference?
Hopefully it don't start to stink too bad once the weather warms up man... 🍿
Those Taramps HD 3K can get it done for sure, just set your filters and levels correctly. This is a vid of another HD 3k amp on better electrical shared with me after he built the design I supplied.
I got the MD series one ohm version. Everything rated at 12.8v. My electrical stays at a consistent 13.0-13.8.
just play music and look at the red clipping indicator.
The DSP is being bypassed right now. So, it can't be that.
did you actually measure the impedance of your midbass to see if its actually 4 ohms? Well we will know tomorrow when you swap the speaker wiring to see if its actually the amp or the speaker itself thats not impressing you. I did say that american bass driver's specs ****** but you still got em haha.
I had to make some decisions on my own. I have the VFL 8's in my truck. So, I figured the VFL 6.5 would be alright. How do I check the ohms on the speaker? Do I just put the multimeter on 200k ohms and then put the red to positive and black to negative?
my buddy just did 147db today on taramps md 3k with stock everything even hu,, no big 3 or even 2nd batt (has one ain't got it back in yet) he just got traded FI TEAM 18 and box so big he'll have to move wires for batt..
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
(NEW) Pioneer 9" DMH-T450EX Digital Multimedia Receiver with Weblink - $189.99 - Free shipping for Prime members...
The one you linked is still a bit iffy if you intend to push things. Consider the cells are rated 100A Max discharge which means if they're the...
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
BOOMINGRANDPA
