Need bass for 100 dollar in a tight space?
RockyBalboa
26
Dallas
I have a c10 chevy truck and have some what of a new vehicle factory sound in it now. I am happy with what I have but would like a little more bass. Not shaking the house windows bass just a little more added to what I have . I have limited space with the single cab and also would like to hide things as much as possible. I have a taramps 400x4, 50w rms dash speakers and 85wrms rear 6x9s in it now. I am undecided on connecting dash back up to the taramps at the moment.
Looking around the
rockville 8" low profile sub seems to fit the bill as a all in one deal with included amp. On the other hand I can get a pioneer IB slim 8" sub for about 65 dollars and hook up to my current amp. I am assuming the box size is not a great factor with the free air slim sub. I can make the box myself from MDF.
Anyone have any experience with the items I listed above or see another route I should take?
Looking around the
Use two of the channels on the amp to power this sub. Build a box for your sub. Sell the 6"x9"'s if you can and get some 6.5" 2-way door speakers. Wire them to the other two channels on the amp. Good luck!
Go to walmart. Get a Blaupunkt 8" subwoofer for $28 and the Dual XPR82D amp for $60.
Or a Taramps Bass 400 and a dual 4 ohm subwoofer that is in your budget and size requirements.
I can vouch for the blaupunkt subs, im been running 2 10's running the mono 600watt @2 ohm sub channel on a pioneer 9605 5 channel for over a year, they haven't blown and sound better then they did when new. Paid $18 a piece for them, I didn't they would last 2 months LOL
what do you guys think about this set up ? About 100 dollars over my budget but figure time to make a box and sound quality over some of the underseat units this might be the way to go??? Can I piggy back power and rca off my other taramps 400x4? Still thinking its a bit much bass though.
19688
19689
Those under seat setups are absolutely horrible.
I would go with the Blaupunkt I recommended but the Kicker will work. Just double your budget that I would use to build a nice box for the Blaupunkt 8" subwoofer.
Thanks for the input guys. Again not looking for window shaking , trunk rattling, just looking for a little more bass. I can feel the 6x9s on the seats , bass. Im running 63watts x 4 , two kicker dash 3.5s and two alpine 6x9s.
Do you guys think a10" blupunkt rated at 300 rms and the taramps bass 400 @ 214watts at 4 ohm, be ok ?
Will the sub over power what I have as far as sound coming from 6x9s and 3.5s?
Should it run cool for long periods of time?
Im assuming , the lower amp wattage will add longevity to the sub?
Should I go to a 8" sub with the taramps 400? maybe better suited to what I am running and a little more compact.
19700
Taramps 400
19701
165
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
120
468
RockyBalboa
RockyBalboa
Dallas
Louisiana_CRX
    May 18, 2024
    May 16, 2024
