2020 Chevy Silverado 1500 Crew Cab Amp Install
  • 2
BoomerJ
Wanted to share that there is indeed enough room for some amps. Shown 2- Fosgate 1000 on the back wall with 3sixty.3 processor. This is my truck with bose amp using harness to bypass. Moved a few items around on the wall. Big shout out to Flat-Out Auto in Buford GA. Awesome work in progress. More pics to come.
Wanted to share that there is indeed enough room for some amps on back wall 2020 Chevy Silverado 1500 Crew Cab. Shown 2- Fosgate 1000 on the back wall with 3sixty.3 processor. This is my truck with bose amp using harness to bypass. Moved a few items around on the wall. Big shout out to Flat-Out Auto in Buford GA. Awesome work in progress. More pics to come.
Did this ever get more photos?
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
Are you planning on upgrading the alternator and add extra batteries?
776
699
BoomerJ
BoomerJ
Georgia
SchecterOJ
    May 19, 2024
    May 18, 2024
