I cant decide between these 2 speaker setups.... please help
coreyb73
I plan on buying new speakers setup for my car but I can't decide which speakers are better. I will be getting one pair of the 4" and two pair of the 6.5".
The amp I plan on buying to power the speakers is https://www.zapco.com/st-6x-sq but if anyone knows of a better 6 channel amp to power the speakers please recommend.
Kicker
6.5 https://www.kicker.com/CSC65-Coaxial-Speakers-4-Ohm
4" https://www.kicker.com/CSC4-Coaxial-Speakers-4-Ohm
Polk Audio
6.5" https://www.polkaudio.com/products/db652
4" https://www.polkaudio.com/products/db402
Thanks in advance.
So, why 3 sets of speakers? I would recommend, one component set up front.
Crutchfield is saying that no after-market tweeters are going to fit the factory ones specifically, so I'll have to make a special mount for it. So instead of getting a component setup, I was just going to replace ever speaker that is not a tweeter. My car is a 2010 VW Jetta with a 10 speaker system. In the front I have 2 tweeters, 2 midranges, and 2 full-range and in the back, i have 2 tweeters and 2 full-range ( according to Crutchfield).
Sounds like you're describing a 3way setup in the front and if so, just go with a nice 3way component set. Focal, hertz, diamond audio.
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
819
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
coreyb73
coreyb73
Tennessee
ItsHammer
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
