4TH ORDER FOR 5 15s.
That build is no joke though. 54,000 watts, a shitt load of lithium, three alternators, and 6 team Fi 18's. $$$$
And we still have not seen any numbers posted.
You could throw 30 grand worth of equipment and materials in sealed boxes and it would be loud, and without numbers I wouldn't be throwing that around as a testament to whatever meme box alignment you think is going to be OP's silver bullet.
You right about that. I've seen alot of set ups with 1000s of dollars put in to it and still doesn't make it to 150-160 SMH
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Rudeboy Rasta
Rudeboy Rasta
Sacramento California
Rudeboy Rasta
