H/O Alt, volt drop in reverse and at idle.
  • 6
Lowkey
I have a 2003 Hyundai Santa Fe with the 2.7L V6. I installed a high output alternator from AutoTech engineering, 143 amps at 650 RPM and 286 amps at 1800 RPM. 1/0 ground directly from alt and a separate ground from battery. Using the factory power wire (from the old alt) in addition to a new 1/0 power run. Alt came with a 2 wire clip (original harness not used) 1 wire goes to alt top post and the other to a 12v ignition source (I used a fuse tap).
Voltage fluctuates a bit but in park, neutral or while driving it sits around 14.7-14.9. When I'm in drive but stopped, like at a traffic light, it will drop to low 14's. In Reverse it drops to mid 13's. Is this normal activity?
I'm using a volt meter that plugs into the cigarette lighter which I know isn't great (I've ordered a legit meter already) could this be the issue entirely?
It's also possible that the auto parts store gave me the factory sized belt when I asked for one .5" shorter. I googled this after the fact and realized that the 79" belt he gave me is the stock size. Would this somehow cause lower voltage in reverse and at idle?
I'm wayyy out of my depth here any advice/insight would be really helpful. TIA
What kind of equipment are you running? If your equipment is pulling a lot of current, your voltage will drop when your alternator is supplying 143 amps verses 286 amps. Dropping lower in reverse than stopped in drive doesn't make much sense. Is there a difference in engine speed between reverse and stopped in drive?
If you have a high revving motor, the pulley can only be so small. High revving motors can over-spin an alt, so they have to put a larger pulley on say a 6500 RPM DOHC v6 vs a 5000 RPM OHV V8. So the lower revving engines will make more alt power at idle, because the alt can spin faster at idle.
If your motor doesn't rev that high, then there very well could be a separate issue. I've been around a lot of 4 cylinder honda motors, and they tend to have this problem. Some of them won't charge at all at idle, like the alt is spinning so slowly that it's not even charging until they hit like 800 or 1000 rpm. Seen that quite a lot, actually.
Just have a single CAB-22, wired at 2 ohm so 1500 RMS. This oddity happens regardless of having the radio up though. I can listen more carefully to the engine next time and see if I hear an audible change when I shift into reverse.
*edit* I went out just now to see listen, it definitely has a shift in engine noise in reverse, I'd say it sounds softer/slower. Oddly the voltage didn't drop to 13s this time but seemed to settle around 14.4/5
So your alt starts charging when you get a little over idle RPM? How big is the pulley on the alt?
I'm not sure because if I'm in park and idling its in the high 14s but when I put it in drive it drops until I let off the brake. I suppose its idling higher in park then in drive with the brake applied? I'm not a car guy really so I'm not sure if that makes sense.
Not sure on pulley size, I could get the measurement I'm sure. They (Alt maker) did say that it would be smaller than stock and it typically needs a half inch shorter belt. *unless your tensioner is able to pick up the slack*
Yes, going into reverse drops engine RPM's by 100-200 rpm usually, so your voltage is going to drop even more when you put it in reverse or drive.
This is a common problem with smaller motors that rev high, like I say. An alt can only spin so fast before it breaks. So if an alt can only spin at X rpm, then X alt RPM on high revving motors is reached at a overall higher RPM. They can't let you spin that alt so fast at idle that it overspins itself if you ever rev up to 6500 RPM.
So say my explorer which revved out at about 5000 RPM, my alternator is spinning faster at idle because they can put a smaller pulley on my motor, since my motor spins 1500 RPM's less than yours. It's just gearing, essentially.
Lowkey
Lowkey
Lincoln, Nebraska
Bass Dad
    May 19, 2024
    May 19, 2024
