Single wire HO alt hookup
  • 2
oxsign
No Affiliation
6,046
34
Orlando, FL
So I have a mechman alt I used as a secondary in my old setup. New truck and I only need 1. Is it possible to connect and remove the battery light that will come on. Or is it even possible to use as a primary alt?
Truck is an ‘01 gmc 4.3.
Thanks for any help.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
476
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
747
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
939
oxsign
No Affiliation
oxsign
Orlando, FL
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
