VW Caddy for SPL from Ukraine !
Talking about one heavy azzed vehicle??? I hope that suspension will hold up. Deff not going to do well on the road. Flat bed vehicle. Awesome build concept. Very Interesting, and alot of work involved
So what's going on behind the car. Power supply lithium manganate, all connected by copper strips. All these subwoofers will be powered by two amplifiers. The power of each amplifier is 28K = 28000Watt nominal (1Ohm). As a result, we get about 56K at the output, taking into account that our connection to each amplifier will be 0.35Ohm - we, even taking into account the growth of impedance, have excellent power.
The first start was made in order to understand the weak points of the car. On a broken windshield, our first result was 160.3DB with a power of 17000W. The glass turned out to be weak, we tried 3 methods of gluing, it does not help, so we ordered armored glass!
doors, loud doors. We tried to approach the hardness of the door with a special approach. Sealant and aluminum profile, inside it is a frame for fixing the skin.
a protective part will be added to the front part later, it will also be decorative
after replacing glass and minor improvements, the result has changed. At the moment it is 163 + Db with a power of 18K.
The next step is to disassemble the door and reinforce it with a metal square around the perimeter. The corner of the door moves very strongly, so this must be fought ...
  • 0-02-05-2279197016fd808325c771d1dec0cf392d5fa4d393386396160f58095f4d8ca4_9a1db099.mp4
    1.5 MB
Perhaps you have an idea of where to dig next and what to do? Now we want to get maximum efficiency from this power. And when there will be a great result, give our large supply of power amplifiers.
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Highest my car has done is a 156. I have 1200w on highs and recently swapped the mids to pro audio mids. This was a challenge as I find many of...
Bratishev_Artem
Bratishev_Artem
Ukraine
Bratishev_Artem
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
