SPL measurement Software
  • 4
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a pizoelectric tweeter and a case to mount it in to keep it safe and suction cups to stick it to the window.
Only problem is you would need to use a actual spl meeter so that you can calibrate it/make a db/voltage chart.
if not then you will have no clue how loud you are with out a reference voltage chart.
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Highest my car has done is a 156. I have 1200w on highs and recently swapped the mids to pro audio mids. This was a challenge as I find many of...
6
982
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
3K
The DD tank has the extreme cab 20hz avg record….160+ for a minute yes….I have
86
9K
s1wheel4
CarAudio.com Newbie
s1wheel4
East Texas
Thor230
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
