Sealed 15 inch enclosure
  • 6
SlugButter
CarAudio.com VIP
4,664
2,147
arizona
Have a 15 inch coming for my personal build. Figured I’d get a head start.
Coming along well mate! Looks like 2.5 - 3 cu feet box. You may have to apply internal bracing depending on the power you are going to run mate.
For sure using bracing. Will also have some leds inside and a volt meter on the box. I should end up at around 2.8 cubes after displacement.
Holy mackerel.
Have you considered overlays that don’t meet at the corner, and using a hardwood quarter round, or does this make for a stronger box?
That must take forever to make (unless you’re lucky enough to have CNC or other automated cutting).
Holy mackerel.
It makes the baffle very strong the way it’s locked in to the T on the back side. I don’t have a CNC machine. After I get the first few cut out I use them as a guide and use a flush trim router bit to just zip them out 3 at a time. Took me about 3 hours to do the corners for this one, and I have a few extra left over.
Patience. LOTS of patience.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
986
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and...
48
7K
SlugButter
CarAudio.com VIP
SlugButter
arizona
Ridinhi
