10w7 enclosure (Sealed JL ProWedge vs. Gately Audio Kerf/Slot Port)
TOURING18
I've been enjoying the 10 W7 in a sealed pro-wedge for a good 2 years now and I'm considering switching things up. Gately is now pre-fabing W7 boxes to JL spec and that has me interested while I save $ a custom 6th order. Will I miss the SQ I've come to love by going ported? I'm only powering the W7 with a VX1000/5i (~500rms) so I'd expect the port will help make up some the lack of power.
Thoughts on what I can expect? Appreciate the feedback.
W7 is a fine performer sealed or ported. Not sure what the JL recommended specs are on the 10" these days but the 12s I've seen or built boxes for seem to like a bit larger than recommended volume to give the sort of sound I like.
I don't imagine you'll be disappointed though, the W7 is versatile enough to do well in both alignments.
Appreciate the response!!! I'm definitely going to give it a try.
I would aim for 10-20 percent larger than recommended on the W7 as a starting point. I've owned a few JL subs including a W7 and the recommended box sizes left me underwhelmed on basically all of them except the W6. Hell, even with the 10W0 when it first came out(the V1) I found it sounded much better to me in almost double the recommended volume. Since you are under-powering the sub by a good bit the larger box volume will help you on that end as well.
Matt
I honestly would hold what you got until you saved up. Going to that Gatley box aint gonna be as big of a jump as you would think, also it would take money away from your 6th order. I would save now and shine later.
Matt
That seems to be the consensus. Gately Audio is pre-fabing the box per JL's spec so ill be limited on going bigger with that option. I just figured going ported accordingly to JL spec compared to sealed would hold me over. But now you got me thinking...
I should prob start calling around asking for quote on a custom box instead for $500
https://www.gatelyaudio.com/collections/jl-audio-specific
Yeah, that's the smart thing to do. :D It's probably going to be a couple years though. It's way more than just the 6th order. I'll be relocating everything to the trunk and probably adding another sub/amp/power. That list will only continue to grow... lol
Hey man, nothing wrong with a hacksaw enclosure to get some bass while you save, lol. If you have some power tools you can eaisely build a basic sealed enclosure to bump. Wood is kinda expensive right now, but a sheet of plywood is enough to make a 3 cube enclosure with the right dimensions.
Matt
I have mine in a ported that I built per JL specs and I love it. I also have a 12w7 but on a sealed box, and I prefer the sound of this 10w7 ported. It takes less power to go deep so I favor it , that is until I port the 12w7 (maybe).
That's good to hear! What are you pushing power wise to the 10?
i use to run a RE HC 12" (my avatar pic, thing weighs 41 lbs, 1200 rms) had it in 3.6 tuned to 29hz, nice
id go big and tune low
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
It surprised me as well. It is a Pioneer Appradio on a JL HD750/1. The adjustments I made were lower the 100Hz to 50% and raise the subwoofer...
23
4K
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
TOURING18
TOURING18
Chicago, IL
nauc
Decebal
    Jun 10, 2024
