Ground Loop, Engine Noise
Jackson_lmr
Alright, so I’m having engine noise and static in the speakers. Here’s what I’ve done to attempt to fix it so far:
1. Power and ground straight from battery to head unit (grounded from back of head unit to battery negative)
2. Grounded rcas to back of head unit.
3. Checked grounds, all grounds measured 0 ohms (grounding bolt, distribution block, wires at amplifiers)
4. Replaced all RCA cables with high quality, triple shielded cables
5. RCA cables are ran on opposite side of vehicle from power, except the remote wire is ran with the RCA cables.
Just discovered, the noise gets worse when I unplug the rcas from the head unit
Any other ideas? The sound stops when I unplug the rca outputs from dsp to amplifiers.
This is my equipment: Pioneer DMH-1700NEX Head unit, Phoenix gold SX2 1200.1 and 800.4 amplifiers, and Phoenix Gold DSP.8.
If this is in the sticky I’m sorry but if you haven’t tried grounding the hu frame to the metal in front of it in your dash, that’s a good idea.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Jackson_lmr
Jackson_lmr
Twain Harte
hispls
    May 18, 2024
    May 16, 2024
