What I do I need to know when buying a simple replacement sub?
  • 4
Zipzoom+
CarAudio.com Newbie
TN
My stock sub got blown in my car. From research I know what size it needs to be but I don't know what else I need to know if I want one with similar specs to my bad one.
All I want is to get one I can screw & plug in and be done with it.
You'd need to figure out "impedance" and be sure to match that or you will damage your factory amp. It should be either 4 ohm or 8 ohm but it could be something oddball with a factory system so it would be good to try to confirm. It may say on the speaker itself, otherwise perhaps Crutchfield has the answer.
Also it is very likely you will not have enough space to mount most high powered aftermarket stuff so shopping something cheap over at Parts Express may be your easiest for plug and play option.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
462
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
356
Zipzoom+
CarAudio.com Newbie
Zipzoom+
TN
hispls
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
