sub box (room setup help)
  • 5
kayan zidan
israel
hi
i have a scar audio 12 (EVL-12 1250Wrms )inch sub in my room and i feel the lack of punch and i know that a proper box can help(looking into a ported box)
I changed the subs location it now sounds cleaner but still feels like its lacking a punch
i have it pointing upwards because i think it sounds the cleanest that way and i don't have many places in my room to put the sub in so that's another problem
any tips on sub box size or location how its supposed to be oriented for good punch and still having a clean sound would be much appreciated ( i can add photos of the setup)
and i know its not the amps or anything they are good enough my Monoblock pumps good amounts of energy into the subwoofer
In a room you want to corner load your subs. Try putting that box in the corner of the room, sub facing out port facing up and seeing how it sounds.
Getting punchy bass in a room depends alot more on the room Acoustics and positioning than in a car from my experience. Generally enclosures in a home will have the sub or port down firing and the other firing out into the room. I'm not going to pretend to know the science behind it, but it just works.
What is your box tuning?
Matt
Been many years since I ran car subs in my room, as a teen did it all the time. But yeah, corner loading, and big ported boxes tuned to what you’re listening to. We use to face the subs into the corner for loudest bass, ports were always on the sub baffle when I built boxes, so they loaded off the wall too. Could get pretty loud on low power. I liked playing with overall loudness, box tuning, but didn’t really care about flat response or any of that, so loaded them into the nearest corner when testing stuff for SPL mainly (you know like, "let's see how loud this is outside the house" 😅 .
Basically in a room you find the sweet spot for your listening position where you will be sitting, so it will sound better and or louder in different spots of the room. You move the subwoofer around and retest every time until it works well where you will be listening from, or try the “subwoofer crawl”, look that up for tips on that. Being in the bedroom, is more studio monitoring and or home theatre positioning which will apply to what you are doing so look stuff up on those types of subwoofers.
Matt
thanks a lot for the help
ill try it but the box that is currently being used is very old and i know its not tuned to well so i need to build a new one and i dont know where to start
Matt
thanks for the help
ill try that and check which sub box I should build
do some research :)
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
A little DAP will do ya, drill, feed & seal, done.
727
kayan zidan
kayan zidan
israel
some dude
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
