Subaru WRX HK+Starlink with aftermarket HU
Ghackt
Miami
This is a strange one for me to figure out and I’m sure there is a audio guru on here that worked with this system before.
so I replaced my WRX headunit with an aftermarket. My car has Starlink telematics system. The radio was a plug in and play with retained OEM backup camera.
so after plugging everything back in my starlink above head light is red. The odd thing is I can hit SOS and the Roadside assistance and it works.
someone stated it’s because the impedance changed when I replaced the head unit so they said either the front tweeters or the front speakers which telematics controls needs resistance lower than 10ohm or 10ohm to get the light to go back to white(green) does anyone have any insight. I’ve looked all over the forums. Couldn’t find an article.
I wish I could help you but I yanked the Starlink box out when I replaced the HU in my 2019 WRX. It's a shot in the dark, but the cat here may be able to help you: https://www.autoharnesshouse.com/S1.html
I can't see how the resistance would have changed if you left the Starlink box and factory speakers in the car though...
id assume because the wattage of the replacement HU and output of it being rerouted.
105
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
Ghackt
Ghackt
Miami
Ghackt
    May 19, 2024
    May 19, 2024
