Help getting info on this amp
Name'sDEEZ
121
15
Earth
Whats up forum i recently got a vehicle and saw that they had a system installed. I followed the wire and surprised that they left the amp there. I searched google but i get different language results and the english ones just mention the name. The amp is.
Soundstream
D-tower series
DTR1.1400D
Anyone know anything about this amp?
i remember those. make sure you have good grounding and dont clip it too hard. it has a tiny (but sufficient for normal operation) ground wire for the preamp, and the outputs already work pretty hard. other than that, expect decent enough performance for a mid-range map
What do you mean preamp ground wire? Where is it? And thanks for this added info by the way.
its internal. a small black wire that jumpers from the preamp board to the main board or section. its not meant to carry any meaningful amount of current, just kill any noise, but its direct circuit parallel with the ground, so if you have poor grounding, the excess current will go through this tiny wire via the rca shield and can burn up.
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
790
Are you turning the volume up higher than before or did you adjust the gain or bass boost?
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
999
Name'sDEEZ
Name'sDEEZ
Earth
akheathen
    May 19, 2024
    May 19, 2024
