Installed JVC HU w/ Maestro RR Getting White Noise -- Please Help
  • 4
beefey
CarAudio.com Newbie
MN
Hi All--
I bought a JVC KW-M780BT HU because I wanted Android Auto. The vehicle is a 2014 GMC 2500 no navigation with Bose sound.
The speakers and amp are factory Bose.
Initially, I used a Crux interface kit which performed flawlessly except I couldn't stand that it didn't have RAP support. So I just changed it out for a Maestro RR.
I'm using the Maestro HRN-RR-GM5 harness and feeding audio via low level inputs to the factory Bose amplifier.
The problem: I'm getting a very very high pitched whine out of the tweeters on the stereo. I did not get this with the GMC factory radio OR the Crux interface kit with the JVC HU-- JUST with the Maestro RR. Originally I was running high level speaker outputs on the RR to the amp and the whine was far too loud. Now with the low level it is less but still very pronounced.
When I turn the HU off the noise goes away. It sort of varies with engine RPM-- sort of in and out but not directly proportional.
Any ideas?
Thank you,
Beefey
REF: https://www33.jvckenwood.com/pdfs/d...77.1866673016.1694565323-566774999.1692073427
Uninstall the new component, noi, moi, noi!
Just kidding. This would most likely be alternator noise, especially if it changes with RPM. Make sure that everything is grounded well. In my experience, RF interference is usually via speaker or RCA input/output cables, Check anything new as the entry point for that noise. Make sure anything new is properly grounded to a bare part of the metal frame/body/chassis. Don't assume it is a good one. Always sand/grind the surfaces of anything you are grounding to.
I would tap off the ground wire and do a stationary solid ground wire to bare metal cleaned off, and ground the whole unit and stereo if you can. 14ga or 12ga wire should work perfect
Hi All--
Any ideas?
Thank you,
Beefey
REF: https://www33.jvckenwood.com/pdfs/download.php?Model=KW-M780BT&File=B5K-0943-00&_ga=2.203253777.1866673016.1694565323-566774999.1692073427
I have a 14 2500HD double cab long bed that i will be finally getting something in this coming summer. No Bose just standard system, getting ripped out and start from scratch with a backup camera going in(really needing it put in).
That back up camera is the whole reason i went DD.love it.
thank you for the quick reply ,I contacted LordofBass and the part is backordered but I'm on a waiting list Cheers:)
945
The install looks very nice and clean for sure. Thanks for sharing the pics as well as your experiences
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
beefey
CarAudio.com Newbie
beefey
MN
Bass Addict
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
