Need help trouble Shooting Amp Error
  • 2
Keithsjr
Need help trouble shooting my audio system. Installing a soundstream reserve 45000d 5channel amp, after market speakers up front w/ tweeters. Stock rears and a 10in sub in the truck area.
I extended off the stock speaker wires to the new fronts into a cross over with the tweeters going to the cross over as well. I T'd off with posi tap connectors off the harness off each speaker wire to run to the amp.
I get amp error with all wires plugged in with no sound.
All speakers work if I just have the rear speakers or even just 1 rear speaker running to the amp.
No sound if just the front are in the amp or if 1 front is connected there's no sound as well.
Maybe a short in the front speaker wires going to the harness? But I don't get why they all play minus the sub if just the rears are connected.
Or should I try running the speakers directly to the amp instead of the crossover? But then how would I connect the tweeters?
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
77
684
745
969
Keithsjr
Keithsjr
Keithsjr
    May 18, 2024
    May 18, 2024
