2007 Hummer H3 stock radio no sound/door chimes
  • 2
buckwheat42
CarAudio.com Newbie
Hello all! I recently purchased a 2007 H3 with the stock Delco radio with 6 disc changer. It worked up until
two weeks ago when we had a bad rain and flooded the passenger side floor board, and I believe that whole side
of the dash got wet. Now the radio turns on and functions properly aside from having no sound and door chimes
are silent as well. I checked all the fuses for damage and continuity and found no issues. I did do a parasitic draw
test and the radio seems to be pulling 1.75 amps with the car off, doors closed, and key out. This problem is also
intermittent. When I hook up the multimeter, I get that reading of 1.75 amps, but after 5-10 seconds, it reduces to 17 milliamps, which I believe is acceptable. Does anyone know what I should test next and how? I have a multimeter, a tone generator/wire tracer and lots of time.
Water or moisture on any Electronics is never a good practice nor a great out come of operating correctly . If you want to keep that same unit, Id recommend looking at a Salvage yard for plug and play. They usually pull them out when wrecked vehicles come in and store in a dry place
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
861
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
buckwheat42
CarAudio.com Newbie
buckwheat42
Florida
audiobaun
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
