Switching From 8's to 10's
I expect it is 3.9 and will be a little less with the larger subs. It's very narrow and the port probably displaces a fair bit how lot he has it tuned.
Really no way to guess how the peak frequency will change, have you modeled the 4 subs in that airspace and tuning? What does box software predict?
I haven't and really don't know how to. I'm not going to lie and say that I do. I've been looking at the VFL 10's. They are 800 watts rms each. I've been looking at a Smart5 to use as the amp. I wish the SIA5000 would get released.
Download WINISD, add Vats Fs and Qts (the only parameters that really matter) and plug in volume and tuning. Be mindful of units, in winISD you can just click the unit and go from cm to in or ft or whatever by clicking on the unit.
Why not buy the SFB 5K on blowout sale? Worst case scenario it breaks in a year and Sundown just replaces it with whatever newer model because they're out of the SFB.
I went through two SFB3K's. If I bought any other amp it would be the Smart5. I think we are going to add another ¾" baffle and then cut the ten's out. I need to figure how how much displacement my port is. My box is 5.69 cubes gross. I figured .4 cubes for the 8's displacement. That leaves me 5.29 cubes minus the port. Let me do some math real quick. If my math was correct then my port takes up .71 cubes. That would leave me 4.58 cubes for four tens. Shouldn't that be enough? I only have about 44 square inches of port. That's fairly small for 4.58 cubes.
I have a pair of SQubed HDS310s in 4.0@32HTZ and that enclosure gets down on 1500rms on up to 4500, Double Baffle
Can I do that on my phone? Do you want to model them for me? Just asking.
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
816
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
Yea, I'm running 6S2P. 12 cells total, 2 banks of 6. Resting voltage isn't as big of a concern, it's more about charging voltage. LTO shouldn't be...
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio. I have a...
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
djdilliodon!
