Mounting the subwoofer
Dafaseles
CarAudio.com Exclusive
402
192
510
So, this might be a little bit of a noob question...
I have to mount 4 12" FI Q subs. I was looking at them today and I've come across something I've read very little about, but have no actual experience with.
If you look through the holes in the rubber gasket that covers the mounting holes from the top, the hole doesn't go all the way through. If you look at it from the bottom, you can see that there is a hole in the metal basket.
I'm guessing it's the surround being glued onto the basket?
I've read that if I use regular screws to mount the subs (which I've always used in the past.... probably wrong lol), I can damage the surround and it can rip. I don't know if that's true. Just something I've read.
I'm sure some of you OG's have come across this. What's the best way to mount these subs? And with what hardware?
Just want to make sure I do it right
If your worried about the overhang of the surround that covers the hole. Just use a soldering iron to melt the surround covering the hole.
As far as normal screws damaging the surround, that's highly unlikely.
Many people prefer tnuts though since it's much harder to strip out the hole of a piece of aluminum than a piece of wood when you install and uninstall often.
I use 5mm pointed and threaded socket cap screws. About as strong as one would ever need for a sub and the surround isn’t going to tear from the screws. No need to worry about that.
Are you mounting them vertically or horizontally? If horizontally then these should do fine. I recommend the torx to prevent using Phillips head screws and slipping off of one and damaging the surround.
Thanks everyone for the quick responses.
I was worried because I read a thread a while ago about some dude using regular screws on a Stereo Integrity subwoofer with, what I assume, is the same deal with the surround. SI recommends using, if I remember correctly, a screw with some kind of washer I think. I can't remember exactly.
I'll just pre drill a hole through the surround, and mount them. If you guys say it shouldn't be an issue, I'm good with that.
I did take some pictures, if anyone's curious
I don't know if you guys can even see it in these pictures though lol
That's a good idea. The soldering iron would probably put less stress on it than using a drill bit. I have one, so that's poetically what I'll do when the time comes
A hole punch would work as well. Like these:
I did take some pictures, if anyone's curiousView attachment 40898View attachment 40899I don't know if you guys can even see it in these pictures though lol
You can always drill new mounting holes a bit more Center or to the edge if you want/worried at all. Ive done that in the past on some old SPL- 10"DVC 1 ohm subs
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
634
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
Dafaseles
Dafaseles
Buck
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
