An idea for subs!
  • 3
zpromax777
CarAudio.com Newbie
ive currently got two sundown e8v3's and i thought about getting 4 more. these subs are very cheap and i have the room for 6. it would help for your input on amp ideas 2nd batterey? box designs.and would these be louder than sayy 3 12's? or 1 18?
6 - 8" subs would be more cone area than a single 18. I'm too lazy to look up the Xmax of the e8v3's so I'm not doing displacement calculations against common 18's.
I can tell you that 6 of any sub will get pretty loud, but it's all about the box. If I remember the E series should be good for about 350w per sub, so 350x6=2100w.
You would need to know your final ohm load to know what amp suits your needs, but you shouldn't need a ton of electrical besides the Big 3 and a better under-hood battery for "2000w on music".
Matt
I'd be more worried if you had the power to push the subs.
If you don't want to run a large amp more cone area with less speakers is generally better.
On the flip side if you want to run a lot of power more speakers with the same cone area is better.
But if you are going to run 3kw to the 6 e8s it will be rather impressive. 4.5ft³ only allowss for 2 12 or 1 15 in the same space.
Ive seen plenty of these cars with ten inch sub/ subs inverted/facing up and ported to the rear.. even a single 12
348
You have roughly 50 liters total, which will probably work with that sub.
9
So im getting the design together for the 2 12's for the truck. Its back from the transmission shop and the burnouts are nice.... so we can get...
6
zpromax777
CarAudio.com Newbie
zpromax777
california
winkychevelle
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
Latest topics
