Need advise on re-coning Discontinued sub
  • 2
Bigjoncoop
Hey fellaz,
I was just able to get my hands on a Audiobahn 12in sub. I had to get it since these are the only Subs we used to bang back in the day! Late 90s
The subwoofer work but the surround and Cone are in rough shape...
After looking online I have been unable to find any Re-cones for this sub... I have seen some of these subwoofers for sale on eBay with different different cones installed. So I'm wondering how do I know which Recon to purchase that will fit this subwoofer? What measurements are most important or is there any Guides Online?
Also since this sub is working is it possible just to replace the surround? The cone could probably be fixed with some super glue or something. There's no hole in it it's just got some parts that are peeling
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
462
354
Bigjoncoop
Bigjoncoop
Florida
    May 18, 2024
    May 16, 2024
