Port length exceeding area?
Jake321
96
14
Hawaii
So I'm about to order dual 4" ports but to tune to 33Hz I'd have to increase the length from 9" single to 19" dual.
Also was thinking of Tuning it to the FS of Sub 29Hz. (30" Port).
When does the length of the port begin to hit a exceeding length?
Subwoofer:
DD712 1Ohm
When does the length of the port begin to hit a unreasonable length?
Subwoofer:
DD712 1Ohm
Subwoofer:
DD712 1Ohm
When you can't fit the port in the space you're using.
My newest box design has a 62inch port 28hz chamber and a 19inch port 55hz chamber so there isn't any length restriction. Port length is relative to enclosure size and port area.
And tuning to fs won't hurt but I'd tune towards your listening preference or cabin gain first
That's eye opening! Thanks! 🤯
Ok proof your advice wasn't a waste of time.
I went out and bought a 6" PVC Pipe. $55.
Cut it at 34" 2.6 Cubes after Port displacement.
FS of 712: 28.26.
Tuning to 28HZ.
And this build will be for the nvx subs? I had eyed those subs a few times myself
Yea that's the plan. I need to remeasure my cabin gain but the box is quite flat 30-65hz my mids are playing down the 50hz now and I think I'm gonna go 3way with stereo integrity tm8s, SB Acoustics SB10PGC21-4, m25 mkii
I might end up trying the 8inch silverflutes first. Gonna be the first time I cut up my door panels for speakers so it might be a $1000 mistake. Damn door panels are $500 each.
Doing the 3inch on the dash makes me worry though. It's gonna make my midrange so much louder and might pull my sound stage too high. Idk the dsp should help with alot of my worry
I’m definitely tuned in!
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
723
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
896
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
870
Jake321
Jake321
Hawaii
Jake321
    May 19, 2024
    May 19, 2024
