Max output from amp !
So what method will you use to plot the impedance of your woofer in the box in your vehicle? How will you account for impedance changes due to compression if you need to determine power at maximum output?
There is some confusion here. I'm not arguing that you should try to figure out your woofer's impedance as a function of frequency by plopping numbers in software or something along those lines and then getting power from that. We all agree, I imagine, that using something a la the AMM-1 is the way you'd actually do it in practice.
My point is more that this information isn't really helping OP. Maybe he wants to spring for a $350 measuring instrument, but I assume not. He's chosen to go the multimeter route. 2 ohm is the nominal impedance of his sub, meaning that they (the manufacturers) expect it to present that load at some practical frequency in actual application. He should be seeing the right numbers coming out of his amp, and the easiest explanation is that his input signal is too low.
Somehow this thread is devolving into nit-picking minutia that doesn't really help OP. He said that it distorts at 38 - we already know that. We aren't talking theoreticals here. I don't know how he got that number and I don't care - I'm willing to run with it.
OK, so what frequency? How do we determine the frequency when OP gets this all installed and if he is not measuring at the one specific frequency where his amp might actually see 2 ohm how is he going to estimate power?
The correct answer is he needs to set his gain by ear while listening to music if he intends this to play music, if he is chasing numbers he needs to set the gain with an SPL meter to find maximum output. This got over-complicated when OP decided he needed to figure out precisely how much power he is getting without understanding impedance of a loudspeaker system and without the willingness to buy the proper tools to measure real-time power.
Ive been tuning by ear for over 25 years.. and so far havent let me down yet thankfully :oops:
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
You could get a head unit with a proper subwoofer RCA’s six channel for around 150 these days
  • Locked
Apple Iphone 14 pro MAX 1tb / Sony Playstation 5 New I am selling the Apple Iphone 14 Pro Max 1TB , brand new and original . Text : ‪(612)...
84
Sonnyyi
Sonnyyi
Sunrise
    May 16, 2024
    May 16, 2024
