Speaker polarity check question
  • 5
Jimg
216
13
My head unit does not have a cd player
android auto or Bluetooth only
what tools or phone apps are you using to test polarity. Most of what of what I see on Amazon is the FH-168 tester with them emailing the audio file in a couple days after purchasing
this the best option for this task
or are there reliable phone apps and methods other than the fh-168
It's the exact one I use, it always came with a CD. If you can't use the CD, Polarity Pops can be easily downloaded from the web. You can also download a speaker polarity app from the apple store or Android store.
You can test polarity with any mono track, ie AM talk radio. The track should sound centered on the dash. If a driver is out of polarity, then the track will sound wide and diffuse.
You can easily do it this way for free.
206
300
239
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
Jimg
Jimg
Bobbytwonames
    May 10, 2024
3toneEYZ
    May 10, 2024
