Need new door speakers . Need options
sounds_explicit
Looking to spend maybe 400 on total of 4 mids. 6.5's
Going to pair up with 3 xv3 15s I have a rockford 600.4 to use for the amp. Needing some good recommendations on mids to run.. needs to keep up with the sub stage. Strongly leaning towards sundown neo pro v3 but they are last on list for price .Also they wstocbe going in stock door locations do i need just mid bass or do I need mid range ?
Also
Also
Considering you are trying to keep up with 4 15s midbass just isn't gonna happen anyway. 100hz hpf minimum and send it on whatever
Sundown neopro are very good pro audio midranges. Add in a pair of nice tweeters on the apillars or dash corners and it should be ok.
Have you spoken with one of the reps? They should have all that info on file.
640
419
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
468
sounds_explicit
sounds_explicit
cleveland ohio
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
