Need new door speakers . Need options
  • 4
sounds_explicit
Looking to spend maybe 400 on total of 4 mids. 6.5's
Going to pair up with 3 xv3 15s I have a rockford 600.4 to use for the amp. Needing some good recommendations on mids to run.. needs to keep up with the sub stage. Strongly leaning towards sundown neo pro v3 but they are last on list for price .Also they wstocbe going in stock door locations do i need just mid bass or do I need mid range ?
Also
Also
Considering you are trying to keep up with 4 15s midbass just isn't gonna happen anyway. 100hz hpf minimum and send it on whatever
Sundown neopro are very good pro audio midranges. Add in a pair of nice tweeters on the apillars or dash corners and it should be ok.
I am considering upgrading the sound system in my 2013 Ford F150. I have identified three potential head units: the Sony XAV-9500ES, the Pioneer...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
454
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
348
sounds_explicit
sounds_explicit
cleveland ohio
winkychevelle
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
