Refoaming Vintage Clarion SE-9450 4-way Speakers
amix
14
Germany
Hi,
I found a pair of 30 years old, oval shaped Clarion SE-9450 4(!)-way speakers, 150W max. input from my first days with a car. I want to add them to my dad's old car on a soundboard (car is a liftback). Sadly, the foam disintegrates from just looking at it. šŸ˜ƒ
Problem: It seems, the web has never heard about these speakers. So I doubt I will find a refoam-kit.
Is there any way to create custom-foam for this?
All technical info I have is from the packaging box, no manual or the like, so I do not have exact measurements of the actual speaker itself. Since the web does not seem to know this speaker, I will add as much info I could gather, for others to find:
Features:
  • MULTI-AXIAL 4-WAY SLANT ANGLE-TYPE
  • Rear Parcel Shelf Speaker for Car Stereo
  • Slant-angle Mounted Mid-range, Tweeter and Super Tweeter Designed to Precisely Match Car Accoustics
  • High Compliance Non-pressed Woofer Cone
  • Clean and Clean Dynamic-type Balanced and Super Tweeter Cones
  • Heat Resistant Voice Coil and Polyimide Woofer Bobbin
  • Black Molded, Heat Resistant Enclousure with Perforated Metal Bolt-on Grille
Specifications:
ManufacturerClarion
ModelSE-9450
Yearapprox. 1991
Reproduction SystemMulti-axial 4-Way
Size150mm x 230mm (6 x 9in. Dia)
Size with frameTop: 241mm (9.5in.) x 167mm (6 5/8in.)
Side: 48mm (visible) + 73,5mm (under surface) (1 7/8in. + 2 7/8in.)
Bottom: 222mm (8 3/4in.)
Nominal Impedance4ohm
Maximum Music Power150W
Nominal Power60W
Magnet MaterialFerrite (Wo): 506g (17,8oz)
Strontium (Mi): 74,5g (2.6oz)
Alnico (Tw): 10,2g (0.28oz)
Ferrite (St): 6,7g (0.28oz)
Weight (one speaker)1940g (68.4oz)
I'll also add some photos. Also, two shots of the first fracture:
45209
45210
45211
45212
45213
Thanks!
P.S. No, I wasn't that rich as a late teen, I payed 100 DM less for them at a sale! ;) It's funny, though, that, counting today's inflation, at the regular price, they would cost EUR 351 now. :eek:
Perhaps take measurements, then browse eBay for ā€œ6x9 speaker surroundā€, to see if any match up. Replacement surround listings should show detailed measurements. You might want to browse the listings first to see what kind of measurements you need. Hopefully you can find one that is close in size, and not crazy expensive to your location. I donā€™t know much about Amazon, never bought anything from that site, but look there too if needed, and or google search for 6x9 speaker replacement surround.
If anyone has a frequency curve and SPL values for this speaker, please report here! Thanks.
Nice find, they look pretty standard you should be able to find surround.
I found some on ebay for a set of 10" a couple years back.
amix
amix
Germany
Robert1999
    May 16, 2024
    May 16, 2024
