Kicks clipping
  • 5
tan271234
Romania
Hello, today I listened to a kick heavy song and I had clipping only when there were kicks, at 23 volume (hu max is 30, and i set the gain on the speakers amp for 23 vol).At volume 22 the kicks werent clipping anymore. Its the only song that happened to clip at vol 23. Is it a hu problem, is the gain turned up too much or clipping depends on music and I should just turn it to 22 if I encounter songs like these? Speakers are 80w rms and amp is 65w rms. Any other song sounds good at 23 with no clipping. The song is astrology by bbno$.
Since music is recorded at all different levels it's not uncommon to have some light clipping on certain songs.
And midbass drivers typically have some cancellation due to where they are mounted meaning the average person will boost the midrange frequencies with the eq trying to make up for the cancelled range.
I have +4 bass out of 10 and -3 treble out of 10 in the hu eq, maybe that would also be the cause.
Just keep it down if you plan on playing that song.. LOL.. Its not rocket science man
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
844
Don't recall off hand. Both single dins. One excelon, one not.
964
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
tan271234
tan271234
Romania
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
