BEEP EVERY FEW SECONDS
46707
Most likely some internal failure in that head unit. Not sure what they'd charge you to pull one out of one of those cars in a junk yard, but aftermarket head unit of good quality is not that much money these days so definitely don't pay hundreds of dollars for a factory head unit.
First Google link.
Second.
This sound is like a programmed sequence as though something is trying to look for something, i cant see being dirt controls, there is nothing in the menu either and turning TA and RDS does nothing
My thinking is that dirt holds moisture. Moisture from Armorall, sweat, soda or any other thing that may have gotten behind the rubber cover. You see this issue in remote controls, key fobs, window regulator controls, et cetera. I do not think both units would be looking for a folder. Maybe if the units have auto volume control, that may be the issue. If the microphones got damaged, they may be sending signal and the radio is adjusting accordingly. For this you must troubleshoot all theories.
The volume goes up and down correctly on both units, this beeping sounds like its searching its sequenced, i had a parrot system on the van so took it off thinking it was that, the controls do look clean and never know this before
I found this, can it be done with snapon modis ultra scanner which i have?
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
gsc1ugs
gsc1ugs
wigan
gsc1ugs
    May 11, 2024
RedRyder18
    May 11, 2024
