1aespinoza 10+ year member
Junior Member
Dang it! I have been operating on one set of RCAs for ever. Thanks man. I will try this.It was an easy fix, you grounded the RCA jackets to the HU chassis.
Same here. For my own gear, I do it by ear.I've set by ear forever.
Correct. From the amp, disconnect the RCAs that come from the LOC. The picture below points to where you will connect your multimeter test leads. Be cautious that positive and negative do not touch each other. The guy in the video made that pigtail to avoid this issue. Set multimeter to A/C volts. After downloading that 1000 Hz. test tone, play it on your radio at ~75% volume. Now sweep the gain on the LOC until you read the 5 volts that your amp can handle. Boom, Jalapeno solutions. Before reconnecting the RCAs to the amp, turn down the gain at the amp. Turn it up judiciously after that with the radio at ~75% volume.View attachment 47064
Correct.So I have an amp that has an input value of 14v and my LC2i has a 9.5v preout. I wouldn’t have to worry about testing with a DMM (as shown) to set the correct gain on the LOC.
No. For the sub amp's gain setting, you go by the sub you will be using. Formula for that is-And keep the gain on the amp as low as possible?
Yup, I know that feeling all too well.Strangely, the more I know…the more I don’t know
Yup, this too.On previous builds I would just wing it and push some buttons here, turn some dials there and call it a day
Correct.
A/C Voltage= Square root of Watts × Ohms.
If you want your 4 Ohms sub to play 300 watts. 4 × 300= 1200. Square root of 1200= 34.64 A/C volts.
Yup, this too.
