Strapping Amps and Wiring Subs
  • 2
Bigfella1978
Junior Member
30
In the A
I have 2 Sundown Salt 4ks i want to strap together. My subs are dual 1ohm, so my questions is how to I wire my subs to the amps. Will the ohm impedance be to low, or do i have to wire each sub to each amp and gain match each with an SMD DD1
419
553
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Bigfella1978
Junior Member
Bigfella1978
In the A
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
