Strapping Amps and Wiring Subs
  • 2
Bigfella1978
30
4
In the A
I have 2 Sundown Salt 4ks i want to strap together. My subs are dual 1ohm, so my questions is how to I wire my subs to the amps. Will the ohm impedance be to low, or do i have to wire each sub to each amp and gain match each with an SMD DD1
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
145
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
405
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Bigfella1978
Bigfella1978
In the A
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
