Dsp with aftermarket radio
It won't hurt anything. Everyone I know that has added one said once it was setup properly the sound was improved. Depends on what you want to spend. They can go from 160 bucks up to 1k. Even though I have a DEH-80PRS I am going to add probably the Helix I have sitting here later on this year.
897
676
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Mr.Jackson
Junior Member
Mr.Jackson
Stone Mountain Ga
Louisiana_CRX
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
